Gm code not showing outer line of sign.
Sheila
New Member
I created the great sign. Created the cdl file fine. Outside male cut shows on Cdl with males lead in. Shows in sequence by list shows when I created g code, but when I take to the table it's not there. Anyone have any ideas?
It does not look like you created the tool path per our directions on creating one, or the online videos that we have when you select Machine Output. Reason I can tell this is the output picked up the inside parts and not the outside profile, these should be tied together as one object. Step 1 would be to Select All and Arrange > Make a path on the sign, then create a tool path on the part, after creating the tool path grab the tool path and drop it in the lower left corner of your Material.
If the sign is already in the lower left corner then once you create the tool path the kerf or the lead-in is now hanging outside the material, solution is to grab the tool path and re-drop it in the lower left corner. See the videos we have on-line at http://torchmate.com/university, click on CNC Tutorials.
