Fire Table
Discussion in 'DIY Projects' started by tuff7018, Feb 7, 2017.
  1. tuff7018
    tuff7018 Active Member
    Mar 23, 2016
    31
    10
    Some of our students made this custom table for one of our teachers. He wanted a propane fire pit so he didn't have the smoke and wanted the names of his kids and wife on the table. The students had a great time with it and we now have people wanting them to build more.
    Darrin Plank likes this.
  2. Ray
    Ray Member
    May 2, 2016
    66
    Very nice!
  3. Arkansas Metal Art
    515
    270
    Looks awesome. Nice job! How does the tank come out?
    I'd be a little nervous about the curtains :eek:
  4. tuff7018
    Mar 23, 2016
    31
    10
    I'll tell the kids and thank you!! They built a door on the front that swings open. I thought the same thing about the curtains and even having it in the house scared me. He says they use it all the time and they like the ability that it's portable for outside use as well.
  5. Arkansas Metal Art
    515
    270
    Did you clear coat it or just leave bare metal?
  6. tuff7018
    Mar 23, 2016
    31
    10
    Clear coat
  7. Arkansas Metal Art
    515
    270
    What kind are you using? I use an aerosol from Eastwood for bare metal.
  8. tuff7018
    Mar 23, 2016
    31
    10
    It's X-O Rust clear and we add the catalyst hardener with our spray gun
  9. Marc
    Marc Active Member
    Jul 14, 2016
    33
    Amazing concept. I am unsure like many others about the indoor use of a Propane fire pit. I guess if the room has good ventilation.......
    Props to the students
  10. EERCO
    EERCO Member
    Dec 30, 2017
    What tips and settings used to cut this out?
  11. tuff7018
    Mar 23, 2016
    31
    10
    We use 45amp tips with our Hypertherm torch and the top is cut out of 14ga mild steel. Looking at their notes cut speed was 80ipm, initial pierce .12 and cut height was .07
  12. Arkansas Metal Art
    515
    270
    Which Hypertherm? I cut 14g at 200ipm with 45a finecut consumables in a Pmax85.
  13. tuff7018
    Mar 23, 2016
    31
    10
    Powermax 45
  14. LECS-Chad
    Turned out very nice. I would like to know about the whole build with piping and stuff as I feel this is a fantastic project for anyone.
  15. tuff7018
    Mar 23, 2016
    31
    10
    Thank you for the kind words. The regulator and gas line we purchased from www.easyfirepits.com as they come as a kit. I have had students use the ones from local sporting good stores and they only put out around 5psi. So if you like the ability to adjust the flames with higher output I would go with a 20psi adjustable regulator. The flame tubing is 1" stainless and we just capped one end and welded stainless fittings so they would screw into the "T" pipe fitting coming from the propane bottle. The top is cut out of 3/16" HR with a 2"x 1/8" flat bar for skirting. The skeleton is made out of 1" x 11ga sq. tube with 18ga HR sheets for the door and sides. We used 2" x 3/16 flat bar for the outer base for stability. If I left anything out just let me know.
  16. Darrin Plank
    Darrin Plank Active Member
    Dec 15, 2016
    26
    14
