A ablecnc Active Member Feb 10, 2018 #1 how to I join all the segmented lines together in a file example Attachments blue crab102.dxf blue crab102.dxf 63.3 KB · Views: 10
Kchoghead Well-Known Member Feb 10, 2018 #2 Try this.. will have to clean up as needed Attachments crab.CDL crab.CDL 314 KB · Views: 7
A ablecnc Active Member Feb 10, 2018 #3 Kchoghead said: Try this.. will have to clean up as needed Click to expand... how did you do that ??
A ablecnc Active Member Feb 10, 2018 #4 reason I'm asking is I have a few that are doing that am I loading the file wrong ??
Kchoghead Well-Known Member Feb 10, 2018 #5 I first changed every thing to the same layer, then double click to node edit the use node tools to connect the broken lines
