File help, looks like extra cuts or paths inside small areas.
Discussion in 'CNC Cutting' started by EERCO, May 8, 2018.
  1. EERCO
    EERCO Member
    Dec 30, 2017
    Any help appreciated. I am a newer user and making this sign for a animal non profit animal rescue for free . It looks like somehow i have small cuts inside other cuts and not sure how they got there. I get an error that we cant create a male tool path because things wont fit. But then if i click on cut now OR show tool paths i see multiple paths but only in some areas. What is the best way to fix the file.
  2. Kchoghead
    Kchoghead Well-Known Member
    229
    35
    I redrew most of the small parts. the remaining small parts need an online toolpath
  3. Kchoghead
    229
    35
    when i have a file like this I manipulate in node editing the all the small parts I can first. Then I use an male toolpath on them . for everything else i use a online toolpath on the narrow closed objects. so yes 2 different toolpaths. Torchmate university has good videos detailing how to do multiple toolpaths
  4. Kchoghead
    229
    35
  5. Keith Rollene
    Keith Rollene New Member
    Sep 26, 2018
    66
    I have the same issue,,,,don’t know why
  6. LECS-Chad
    Ok importing DXFs with smaller cuts that are shapes.
    First thing I do is BREAK PATH and select the smaller areas. Then I go to the VECTORIZATION TOOL and use a SINGLE LINE.
    This will create a single line inside of the shape.
    Then make a ONLINE TOOL path on those items.
    Check out the DXF Clip art video: This covers the multiple tool path creation and the single line tool.
