DCB Season 3 - Hitch Wagon S3E6
Discussion in 'DIY Projects' started by LECS RC, Sep 5, 2018.
  1. LECS RC
    LECS RC Member
    Dec 21, 2015
    11
    10
    This week Chad wanted us to build him a hitch wagon so Aaron came up with a drawing.
    After cutting all the pipe we cut some caps, welded them on and ground everything smooth.
    After welding the frame up we started cutting and tacking the expanded metal onto the frame.
    Cut Parameters:
    • Table: Torchmate 4400
    • Plasma Cutter: FlexCut 80
    • Material: 11ga/14ga Expanded Mild Steel
    • Amperage: 40 amps
    • Cutting Speed: 90 ipm/120 ipm
    After welding in the nameplate and the handle mounts the Bad Wagon is born.
