Cutting concave discs
Discussion in 'CNC Cutting' started by Thumper44, Nov 27, 2017.
  1. Thumper44
    Thumper44 Member
    Nov 6, 2016
    10
    Newer member looking for little help. I am wanting to cut a design on a concave disk blade has anyone ever done this before or have any tips on settings so the height control will follow the curve of the blade
    Would be no different than setting the height control from cutting warped plate.
  3. Thumper44
    Thumper44 Member
    Nov 6, 2016
    10
    Ok I just wasn’t sure as there is probably a 2-3 inch concave to the disc. I’m gonna try this next couple of days. Thanks
  4. Dnmeistr-LECS
    With respect to that, you do need to verify you have enough travel to maintain the proper distance from the material. Tell me what controller you are using and I can give you some better guidelines.
  5. Thumper44
    Thumper44 Member
    Nov 6, 2016
    10
    Classic table with accumove 3
