cutting a line without the loop
Discussion in 'CNC Cutting' started by EERCO, Jan 14, 2018.
  1. EERCO
    EERCO Member
    Dec 30, 2017
    How do we cut various thickness of lines without it being an actual loop of nodes? Such as drawing hair on a horse mane.
  2. GarageNerd
    GarageNerd Active Member
    Nov 15, 2017
    40
    43
    There' probably a way better answer but I use center line and delete the original path. You could also break path and break node and delete the unnecessary parts.
    EERCO likes this.
  3. Kchoghead
    Kchoghead Well-Known Member
    229
    35
    If it is not a connected cut ie circle or any closed object, then you would use the online toolpath and the torch would cut just the line
    EERCO likes this.
  4. Kchoghead
    229
    35
    on small closed shapes that don't have enough room for your lead in you can also use the online toolpath option
  5. Dnmeistr-LECS
    To create a line that will add definition to your part, use the node edit (pencil icon), you can trace that part each time you click it will place a node. To snap a straight line hold down the Ctrl key when you click, click apply to get out of that mode where you can then change the dimension of the line. You would not include these lines when you make path on your fully defined interior and exterior objects. Select all of your definition lines and make path then select all of your fully defined objects and make path then you can create your male and online tool paths. Modify the sequence so that the definition lines cut first (Layout > Sequence by List) then create the file.
