Cutting 6x6 square tube?
Not a problem as long as you have enough clearance, draw a rectangle representing the tube and drop in into the lower left corner. Place the objects you want to cut inside the rectangle, create the tool path not including the rectangle, machine output to create the .gm file. Align your tube along the axis that you drew it in, set program zero bottom left of tube.
