Cut sequence in nesting
Kchoghead
I have file that i need to cut but it came already nested. can some tell me how to sequence to make the torch cut out the parts that are nested in the other parts first then cut out the rest normally, Attached is the file for reference .
If you can click on the parts individually then you can go to Layout > Sequence by List click on Tool Paths Only and you can move the parts up and down the list. Alternatively you can click on your first tool path then under choose Start Sequence and click on the objects themselves to define the cut order.
