Convert back to text?
Arkansas Metal Art
Once you have converted "text to graphics" is there a way to convert back or is there a way to change the slant or italics of the letters after they are converted? Thxs.
The only way you could get the graphic back to text is if you haven't closed and saved the file . Once you close and then reopen the file it is now only a graphic. Of course if you were working on the file and decided you wanted to change, as I'm sure you know is the back button.
If this a premade or completed file you could always "break path" then pull the text/graphic out and re-type your desired text back in.
thought more time consuming node editing is always an option.
