Compatible Fonts
Discussion in 'General Fabrication' started by Bentup, May 1, 2017.
  1. Bentup
    Bentup Active Member
    Apr 24, 2016
    What are some compatible fonts for the Cad/Cam software? Look to install some new ones for some classy signage.
    90% of the fonts you download will work without issue.
    So www.DAFONT.com is my favorite for fonts.
    To install them into the TMCAD go to FILE/INSTALL/FONTS
    This will bring up the INSTALL FONTS screen.
    Press RESET
    Then SEARCH NOW
    Then INSTALL ALL/CLOSE
    You will need to restart TMCAD once done.
    FONTS!
    OcalaWill likes this.
  3. OcalaWill
    206
    Oooh - Thanks for that link to the fonts!
  4. Bentup
    Apr 24, 2016
    Thank you so much! I knew it had to be something simple. However, some of the fonts loaded and some not. Any suggestions?
  5. Dnmeistr-LECS
    You may have to first install the font into Windows, drop the font into the Windows\font folder, then go through TM Cad to install fonts.
  6. Kchoghead
    Kchoghead Well-Known Member
    229
    35
    Thanks for the font link...looks like a lot of good ones
