Calculating Inches Cut
Discussion in 'CNC Cutting' started by JoeRob, Sep 20, 2017.
  1. JoeRob
    JoeRob Active Member
    Nov 9, 2016
    28
    In TM cad-cam 9 is there a way to calculate total inches cut per item? and a way to calculate how many pierces?
    Break path select all, that is the number of pierces, shown in the upper left. Cad does not calculate linear inches, what it can do is show you the total area of the material, under the Machine menu.
  3. JoeRob
    Nov 9, 2016
    28
    Thanks for the info!
