Cad Question
All of a sudden the origin lines are showing up on my cad. If I hit reset origin they go away. Any ideas how to turn it off completely?
Also it is now opening multiple windows when I open multiple files, it used to all go onto 1?
okay its all back again, also when I control D it now goes to 5:00 where as before it went to 2:00.
The dam origin lines are back and multiple instance is off and has been off?
Thoughts?
To remove the origin lines you can go to Options and Reset Origin. To modify setting for duplicate go to Options > Torchmate Setup > General and change the X and Y coordinates for Duplicate.
I know how to get rid of them but why now is it showing up every time I open the cad? It never did. Also why is the control d changing? What's making these changes?
Is your Origin defined at bottom left corner under Layout > Material Size, if not it will always reapear when you open Cad software. No idea on Ctrl D changing, you have read/write priviledges to the Cad folder on your C: drive.
