Any words of wisdom on 24 ga
Discussion in 'CNC Cutting' started by Toddy, Sep 21, 2018.
  1. Toddy
    Toddy Member
    Jan 30, 2018
    7
    I always seem to struggle cutting 24 ga I run her in manual with the water right up to the steel and that usually gives me the least amount of cut loss errors. I will check my notes and play with speed a bit but run book numbers for the rest. I have several hundred parts to cut out all the same and was looking for any advice. I'm running a 4400 accumove 2 flexcut80 precision cut consumables
    stjefrey likes this.
    Run it balls to the wall with the least amount of amperage. Cut Loss message is referring to plasma losing the cut due to piece dropping out before motion stops, to alleviate this Login as Admin go to Machine Settings, on Inputs tab change Aux 1 to User.
  3. stjefrey
    stjefrey Member
    Oct 12, 2018
    11
    I having the same problems. Did Dnmeistr-LECS suggestion work?
  4. stjefrey
    stjefrey Member
    Oct 12, 2018
    11
    Fixed the "Loss Cut" problem. The fine folks at Lincoln (Chad) helped me walk through it. He even emailed me on Sunday!
    Cut loss is a setting.
    Log on
    Admin
    Password 1234
    Machine settings
    Input
    Change OK TO MOVE to USER
    Change the denounce to 0
  5. GarageNerd
    GarageNerd Active Member
    Nov 15, 2017
    40
    43
    This 100% fixed my problems. Much better than the font cut 24g answer I got from someone on the tech support line.
