You can do it a couple different ways depending on the look you’re trying to achieve. Normally I weld a small bolt to the back of the top layer and then put holes in the rest of the layers so they all lay together. If you want to space them apart just add a nut to the bolt in between the layers.Nice! What do you use to space your layers? How do you attach the layers to each other?
