Been learning tracing and node editing for the last month, went to shop today to cut 11 projects but once I imported the GM file into the VMD random solid red lines appeared that were not visible in Cad/Cam 9. Tried to cut a few and machine cut these random lines and ruined 6 pieces. Tried male tool paths and online tool paths as well as changing lead in points. Some of the drawings had a white broken line that eventually led in to the solid red lines. Can't seem to figure the problem out. Any thoughts would greatly be appreciated.
Currently using Cad/Cam9 and VMD set up file 1.3.2. Also when I set the program zero and use the run from here function it asks to search for current job I enter yes software replies job not found. When I click on run job the torch/machine moves randomly to a start point it seem to select Thought and possible solution for this would be greatly appreciated as well.
Gary
Gary
