Accumove controller noise
Discussion in 'CNC Cutting' started by Garys Metalworks, May 4, 2021.
  1. Garys Metalworks
    Garys Metalworks Member
    Jul 3, 2018
    20
    Hello
    I have a Torchmate 4400 that is making a growling noise when starting up the first time of the day. It sounds like a cooling fan going out. The sound stops and the controller seems normal after about 20 to 30 seconds. The sound returns the next day or later. Has anyone had a similar issue or replaced a fan in the Accumove controller. I contacted the tech department, they said blow it out with air. It sounds like there may be a little more to it. I would appreciate any advice. Thanks, Gary.
    LECS Hunter likes this.
  2. LECS Hunter
    LECS Hunter Administrator
    Feb 10, 2021
    54
    Thank you for reaching out, if you find it difficult to receive an answer from the community, you can try this Facebook page: https://www.facebook.com/groups/170485276316053/about
    Did you try tech supports solution?
  3. Jeff Bradshaw
    Jeff Bradshaw New Member
    Sep 18, 2021
    I am having the same issue. Did you get it resolved or have a replacement aftermarket part you found?
  4. Garys Metalworks
    Jul 3, 2018
    20
    I still have the same noise at start up. Sounds normal after 30 seconds or so. Support was no help at all. If it gets worse I guess I'll try again.
  5. Jeff Bradshaw
    Sep 18, 2021
    I pulled my Fan out of the Accumove today to see if I can get one some where else and really could not find a perfect match other than size. So I did what they told you to blow it out and it felt like it did not do much and then I pulled the tape off the back that says what it is and a little metal plug came with it to expose the fan shaft and I put a small drop of TriFlow lube and now it is quiet again. I am not sure how long it will last but for now runs like it used to. Hope this helps and if I find a crossover fan I will let you know. I worry about the fan going out then me cooking the motherboard in the Accumove.
  6. Garys Metalworks
    Jul 3, 2018
    20
    Thanks for the info. I guess I better get to work on mine. Did you need to remove the controller from the table or were you able to open it up in place?
  7. Jeff Bradshaw
    Sep 18, 2021
    I crawled under and did it in place. I removed the side plates and then it sagged then I had to remove the top screws. Then the red cover came off. Just be careful the switch has 2 small plugs that popped of but it was not a big deal to reattach when I put it back together. By the way I only pulled the sticker just far enough to expose the cap and shaft so it realigned real easy going back together. I did find almost a exact match now but it does not have the nice threads so I will wait for Torchmate to get back to me regarding a replacement or where I can get it since the ones I found are out of China.
  8. Garys Metalworks
    Jul 3, 2018
    20
    Thanks Jeff.
  9. Jeff Bradshaw
    Sep 18, 2021
    No problem at all. They did call me back from Torchmate Lincoln and they have plenty of those fans in stock and the cost is $11.75 each if you need one. I was told they rarely go out but he mentioned there might be bad ones out there. I told him what I did and he said it will probably last for some time but if I need one they are in stock. I think next time I place the order for consumables I will add one of those fans.
