I had been running a program to cut a flange. Everything was ok for a bit then an issue started. Torch head lowers to material, plasma starts then before it starts to move the plasma arc is lost but it continues as if it still is cutting. Reset the program. Datum reset multiple times. Turn machine off and back on. Replaced all the consumables. Double checked all parts were tight. No breakaway issue. Thought maybe it could be the program so i moved ahead to the next cut and i et the same thing. I had been cutting for about 30min before this started. No Faults on the plasma. Turned if off and on several times. Air is clean, dry and cold. PSI is set proper. All settings in job setup set per the manual. Cutting 1/2" stainless. I have been trying to diagnosis this for over an hour. Any help would be appreciated.
