Anyone have any luck cutting 24g? It pierces but no move signal. Edit. Just saw thread below on thebtopic.
"Anyone have any luck cutting 24g? It pierces but no move signal." I was having the same problem yesterday!?!? I would get some cuts but mostly pierces and no movement. Could it be the material was heavily oiled and not receiving a good ground?
You can drop the pierce delay to 0, if that works great if not then you can Disable Ok to Move and enter a Pierce Delay. Depending on your software Ok to Move could be under Tool Library or it could be under Machine Settings once you Login as Admin (password 1234).
