Poor Corners
Discussion in 'CNC Cutting' started by Anthony Lauro, Nov 14, 2019.
  1. Anthony Lauro
    Anthony Lauro New Member
    Oct 4, 2018
    16
    I've been cutting some 16 gauge steel and I'm having trouble getting crisp corners. If you look at the attached photos you'll see the corners seem to blow out or bow.
    Running the book settings at 40 amps. Have varied IPM from 150 IPM to 400 IPM. Doesn't seem to make a difference. Tried new consumables as well.
    Any ideas?
    Try changing the corner to a small radius, this way the torch will not slow down as it does on a sharp corner, as it is the slowing down affect that is blowing out the corner. Also cant tell by the pics but it looks like the lead -in is in a corner which could be compounding the situation. Normally you want a lead-in in a corner so it hides the divot created by the start/stop, in you case you can move the lead-in on a straight edge, but then you are going to get a small divot on the edge. When you double click on the tool path, click on the drill bit icon, double click on the line where you want to place the lead-in as shown by the red cross as you move your mouse along the line.
  3. Anthony Lauro
    Oct 4, 2018
    16
    Thank you!
    I'll try that. Would is the minimum radius you'd recommend on a corner? I'm cutting out type that has been converted to paths. Smallest I go on type height is 1".
    I also tried checking rounded corners in the toolpath menu but it made no discernible difference.
