OK here's the deal...started job cutting 1/4 metal...well dummy me forgot to change speeds....no cut through just a bunch of sparks.shut it down by stop button....changed speed, reset, reset z, went to program zero...run job ....torch touches off and fires but no torch movement...I know that has to do with ok to move...reseated ok to move cable.. ...tried again...same thing...how do i get this reset without shutting down and restarting ? i can cut another file the come back to this one and it will work....I dont know what the software needs to run correctly again...HELP
You can disable ok to move by going to Tool Library and turning off Ok to Move, you may need to increase your pierce delay by doing that.
will the torch move after it fires with ok to move turned off? I was able to move the torch to a new set point and cut a file. i recorded the x and y coordinates of the set point from the first file that screwed up and went back to that spot and tried to cut the file . all it would is the same ...move to first cut,fire and set there
