.gm to.cdl
Discussion in 'CNC Cutting' started by Jim Morrison, Jul 17, 2017.
  1. Jim Morrison
    Jim Morrison Member
    Dec 1, 2016
    9
    66
    Is there a way to convert from a .gm file back to .cdl file?
    Rename the .gm to .fgc or .nc, then you can import the file into TM Cad and it will show up as a line drawing. You will need to delete the lead-in/outs as well as the objects will be slightly bigger or smaller depending on the kerf compensation.
  3. Kchoghead
    Kchoghead Well-Known Member
    Jan 19, 2016
    229
    35
    I always save the cdl without the cutpath or make a copy on cdl file before I generate the gm file
    That is a good practice, save the cdl as your original without the tool path.
  5. Efrain Osorio
    Efrain Osorio New Member
    Mar 18, 2019
    can anyone help me with converting a .CDL plasma file back to a .GM cad file?
  6. Kchoghead
    Jan 19, 2016
    229
    35
    post the file
  7. LECS-Chad
