I cant seem to figure out how to change the voltage setting on Torchmate 4800 accumove 2. Its been set at 127 which has been fine for 14 GA to .1875 , but now i am trying to do .375 and cant change to the suggested 135 and the torch keeps diving into the plate. I played around with auto but the first few cuts are bolt holes and does not seem to help Ive tried looking at creating a path and output settings , also on the machine itself. I can highlight the set voltage but cant change it. any help is appreciated Thanks , Clint
Our height control uses Sample Voltage setting to adjust the Set Voltage, when in Auto mode with this set to On you do not need to change the Set Voltage. The software does this for you, after briefly sampling the voltage it will adjust the set voltage for you, therefore you do not need to change the Set Voltage.
Cant seem to adjust it... I guess its just to user friendly for me. I am used to being able to adjust a lot more settings to dial in cut quality.
