Torchmate® Tips and Tricks
Discussion in 'CNC Cutting' started by LECS Mark, Dec 9, 2016.
  1. LECS-Chad
    I would think you can just open teh .GM in a text editor.
    Replace m64/65 with m50/51
    save as...
    Change the extension to .fgc
    should work???
  2. James1012
    James1012 New Member
    Jun 2, 2017
    Mark, I am very close to purchasing a 4800 and I would like to see if you can do a video or pictures of the machine cutting #4 or #8 stainless Steel with laser paper.
    Thanks
  3. stick
    stick Member
    Feb 28, 2018
    7
    Just got signed up. Looking forward to learning from everyone.
  4. scbron
    scbron Well-Known Member
    Apr 29, 2016
    46
    73
    I am a Accumove 2. I was able to do the rip cut but I am not actually clear what the correct order of operations are. Could someone provide that as a step by step list. Thanks
  5. scbron
    Apr 29, 2016
    46
    73
    I figured it out,
    Open Tool Library
    Set the incremental amount of travel
    Hit Toggle to initiate plasma arc
    Hit the directional arrow to move the distance entered in the incremental travel window
    Hit Toggle again to end the cut.
    Very helpful, more tips please
  6. Dnmeistr-LECS
    See post 13 on previous page, gives you the file as well as steps to run the file.
