Un-weld?
Discussion in 'CNC Cutting' started by Arkansas Metal Art, Mar 29, 2016.
  1. Arkansas Metal Art
    270
    Is there a way to un-weld something after its been saved and undo is not available?
  2. Matt
    Matt Well-Known Member
    Dec 15, 2015
    112
    30
    58
    You would have to go to node edit, break the node apart at the area, and rearrange them and reconnect them in a way that matches how they were before the weld.
    Arkansas Metal Art likes this.
  3. Arkansas Metal Art
    270
    Thanks.
  4. Gamble
    Gamble Active Member
    Feb 15, 2016
    30
    13
    Draw a line or box through the part completely. Extend it past the part actually. Do an XOR weld, then go back and delete the parts that were over extended.
    Matt likes this.
  5. Matt
    Dec 15, 2015
    112
    30
    58
    Not a bad solution, both methods work depending on the shape of the part where you need to unweld.
