14g box dividers for a customer. 76 dividers broke on two sides. Break lines sure make it easy. Second pic is dross right off the table. Having really good results with 14g.
14 ga is perfect fo rthe smaller projects. one of the sizes we use the most. Im at the same settings!
When you do a bend line (cut) is that just a line with online cut path or is there a closed narrow rectangle to it? I have never tried that. Looks great!
Just a straight line with an online tool path. Works great for stuff like this. I usually leave 1/4" at the connection points. Then just break it over the edge of a table. Any less than 2 or 3" on either side and it works best to sandwich it in a vice between two pieces of angle iron that are longer than your part.
