Kerf/Cup Issue
Discussion in 'CNC Cutting' started by DanGeorgian, May 16, 2017.
  1. DanGeorgian
    DanGeorgian Well-Known Member
    Jan 17, 2017
    102
    23
    below i have a dilemma. my 65a tips sit nice and close to the material to keep my kerf nice.
    my 45a tips are recessed and end up giving me the same kerf as my 65a.
    does anyone have the part number for the style cup i need for the 45a tips?
  2. Arkansas Metal Art
    270
    What plasma are they for?
  3. Larry Cameron
    Larry Cameron Well-Known Member
    146
    29
    I think you may have the hand torch shield not the machine torch, that's why it is recessed.
    Larry Cameron
  4. DanGeorgian
    Jan 17, 2017
    102
    23
    oh ya sorry its a hypertherm 65. my cups are different sizes. the 45a is quite a bit shorter than the 65a. i need to know what shield i should be using for the 45a cup. all the shields i have are for 65+ and the guys at the welding supply shop dont have a clue how to help me.
  5. Larry Cameron
    146
    29
    You only have to google Hypertherm and look for the machine specs and it will show you what parts and part numbers you need :)
    Larry cameron
  6. Arkansas Metal Art
    270
    [​IMG]
    If your using the hand torch, the 45a and 65a shields are the same 220818. If your using the machine torch, the 220955 is for "unshielded cutting" and the 220817 is for "shielded cutting". So the 220955 would probably set flush to the nozzle and the 220817 would set away from the nozzle.
    Here's the manual if you want more detail.
    DanGeorgian likes this.
  7. Dnmeistr-LECS
    Man you guys are making this way too easy, thanks for looking out.
