File retrieval
Discussion in 'CNC Cutting' started by bigjoe, Jan 12, 2017.
  1. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    156
    88
    i messed up on some settings on a cut "Gm " file went to the CDL file and broke path and the whole image erased , is there a way to reverse or rework a Gm file? Basically want to add 1/4" overlap on my online lead in.
    You can rework a gm file, rename and change the extension to .nc, then you can select Import and select that file type .nc in the drop down list, browse and select your file to import. Keep in mind this file will be slightly larger in the outside profile and smaller for the inside shapes by the kerf width, you will need to edit the nodes to delete the leadins and then check to see that all shapes are closed by going to Edit > Select by > Open Objects. If you have open shapes they will need to closed, then you can make any changes required, Make Path and then create your tool path.
  3. bigjoe
    Jul 21, 2016
    156
    88
    You guys/gals are great
