Draining the Table
Discussion in 'CNC Cutting' started by John.Close, Dec 8, 2016.
Tags:
  1. John.Close
    John.Close Member
    Nov 29, 2016
    7
    Quick question for the Torchmate Veterans out there, I have a 4x4 growth series table and wanted to replace the water, hooked up to the drain in the back corner, but only water from that "section" drains any suggestions before I waste my time?
    There is no easy way to do it other than scoop it out as best you can.
  3. kb3gun
    kb3gun New Member
    Aug 30, 2016
    66
    Yep, scoop it out. I moved this past summer and swore if I ever have to do it again, I'm building my own one-piece water table to replace this nightmare. Mine leaks now too, so I should have unbolted it and re-siliconed it as well.
  4. LECS-Chad
    I recommend taking out 1 or 2 bolts from the seams to allow a little more "flow". Wet dry Vac and a scooper.
  5. Kchoghead
    Kchoghead Well-Known Member
    Jan 19, 2016
    229
    35
    I put another drain on the other side to remedy this problem.
    Matt likes this.
  6. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    156
    88
    get youself a cheap little bilge pump 12 volts.
  7. Charles Hinze
    Charles Hinze Member
    Jan 20, 2016
    11
    Shop Vac or a 10.00$ drill pump works well depending on how often the water is changed
  8. Steve Woodhall
    Steve Woodhall New Member
    Aug 24, 2016
    Shop Vac make a vacuum with a water pump integrated into it. https://www.lowes.com/pd/Shop-Vac-14-Gallon-6-Peak-HP-Shop-Vacuum/999998030
    The way Lincoln builds the water table it is the fastest and easiest way. I have a pump and filter on my table for re circulation, putting a long garden hose on that will also move the water better than just letting it drain out, however doesn't solve the other side of the growth series table, at least after it's half drained.
  9. Todd_P
    Todd_P Member
    Jun 5, 2017
    8
    66
    I welded 2 additional drains into the other sections and piped them together under the table to a manifold for a single drain point.
  10. Schutte
    Schutte Member
    Dec 12, 2016
    8
    We just finished draining ours this year at school. What a nasty miss. Probably need to do it more often. My plan this summer is to drill a couple more holes and two more drains. It thought I read some were that someone uses a chemical in the water to help keep the metal and and rails from corroding. Any idea?
  11. Todd_P
    Todd_P Member
    Jun 5, 2017
    8
    66
    We use:
    1/4 LB of Sodium Nitrite
    2 teaspoons Physan 20
    4oz of a food grade dye of your choice (we use either green or blue)
    I have no idea where the recipe came from but it should be good for 50-60 gal.
  12. LECS Matt
    LECS Matt Member
    Oct 19, 2016
    7
    The water additive Lincoln recommends is called Green Cut. Its manufactured by a company named Lubecorp. Most welding suppliers like Airgas and Praxair can get it for you or you can go to the following website to find local distributors.
    https://www.lubecorp.com/greencut-cutting-fluid/
