Torchmate® Tips and Tricks
Discussion in 'CNC Cutting' started by LECS Mark, Dec 9, 2016.
  1. LECS Mark
    Dec 1, 2015
    67
    42
    48
    I'm not sure if you guys already knew how to do this, but I figured I would make this video anyways. It goes over the 3 main ways of moving the torch: continuous, incremental, and point.
    Let me know if you learned something new in this video!
  2. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    138
    28
    I thought it was useful, good stuff, keep those tips coming.
  3. Dnmeistr-LECS
    301
    72
    The incremental I use all the time, makes it so much easier to move an exact distance.
  4. LECS Mark
    Dec 1, 2015
    67
    42
    48
    Here's another video on how to rip cut your material. This can be a very useful tool when you need to cut metal sheets into smaller pieces, or when you need to sever already cut sections from a plate that you are looking to save.
    Harlan Cooper and Robert Rooney like this.
  5. Kchoghead
    Kchoghead Well-Known Member
    76
    11
    28
    Tried the rip cut...worked perfectly.. thanks like Mark said, this will very useful.
    Torchmate likes this.
  6. bigjoe
    Jul 21, 2016
    138
    28
    did the rip cut this A.M. wow what a time saver!
  7. Randy Dobbins
    Randy Dobbins Member
    Feb 11, 2016
    wish you could do this with the older models.
  8. Dnmeistr-LECS
    301
    72
    There are many ways you can do it in the older software:
    1 - Go to Aux activate the Tool and jog to cut then deactivate the tool
    2 - Aux to activate the tool, click on Point where you have entered a distance for either x or y and a feedrate and press Move then deactivate the tool
    3 - Or my preferred way. Jog to edge of material and Set Program Zero, click on Midi enter the gcode such as G01 X48 F70, Press Start and it will activate the torch cut in the X axis 48" at 70 IPM and then turn off the tool automatically.
    In TM4 to see the Midi button you may have to go to Configuration > Preferences > Main Screen and place a check next to Midi, also you can go to I/O > Output Lines and change the field to Yes in Display in Output Box to place the Plasma button on the Main Screen.
  9. Randy Dobbins
    Feb 11, 2016
    I have the Torchmate II--What you said should work on mine too?
  10. LECS-Chad
    391
    129
    This will work on all "older" driver software. So TM2/3/4. You can verify by going to HELP/ABOUT TORCHMATE.
  11. Fastyankee13
    Fastyankee13 Well-Known Member
    Jun 3, 2016
    62
    The rip cut is very handy I use it all the time your video was very useful. I was trying to rip cut basically square out of a piece of steel but retaining the factory edge on the one Y and X axes . I only wanted to cut down the one x and Y axes Basically an L shape. I couldn't get it done. Do you have a trick for getting that done with out using CAD??
    AJ
    www.outlawchutes.com
  12. LECS Mark
    Dec 1, 2015
    67
    42
    48
    I guess it could be done if you ABSOLUTELY had to. But if I was you I would just use the shape library to create a shape to your exact dimensions.
    The way you could cut out the "L" shape would be to do the rip cut for exact distances, shutting off the torch and reprogramming the distance at every corner. The federate for your cut would remain the same.
  13. LECS-Chad
    391
    129
    Here is a RIP program.
    Set your PROGRAM ZERO where you want to END.
    Then JOG the head to where you want to start. Half on/off the material.
    Press RUN and the head will cut to the SET PROGRAM ZERO.
    So making an L you would SET PROGRAM ZERO at the point of the L.
    Jog machine to the starts and RUN.
    • RIP.gm
      File size:
      54 bytes
  14. Fastyankee13
    Jun 3, 2016
    62
    Mark , I took the rectangle shape from the shape file and tried deleting two of the edges in the node edit and running that. But I had issues doing that the shape came out weird. There is a lot of times were I just want to do this simple L cut were I just want to cut a corner off of a sheet.
    AJ
  15. LECS-Chad
    391
    129
    you wouldn't generate a shape. Use the GRAPHIC EDIT TOOL upload_2017-4-26_7-21-59.png and assign a ONLINE TOOL PATH.
    bigjoe likes this.
  16. Dnmeistr-LECS
    301
    72
    What Chad showed is slick and easy, better than drawing a shape in TM Cad.
  17. Fastyankee13
    Jun 3, 2016
    62
    I actually tried that method I couldn't get a good L but I guise I could of used the set degree angle tab to get the 90 degrees.
  18. SegoMan Designs
    SegoMan Designs Member
    May 17, 2017
    11
    Chad,
    What file extension is this? it wont open as a G-code (fgc) nor can I import it. I have 3 on the machine.
    Thanks,
  19. Dnmeistr-LECS
    301
    72
    It is a .gm file used on our VMD software with Accumove controller. If you are using TM3 or TM4 then that file wont work.
    SegoMan Designs likes this.
  20. SegoMan Designs
    May 17, 2017
    11
    Thanks for the reply! back to writing a little g code for a rip cut..
