The Shiney Keg Plasma Kutter
Discussion in 'DIY Projects' started by SegoMan Designs, May 19, 2017.
  1. SegoMan Designs
    SegoMan Designs Member
    May 17, 2017
    11
    Hi all,
    Newbie here, I thought I would share a few pics of my build on the 2x2 table. I got a good deal on a new to me never ran gantry unit.
    [​IMG]
    After verifying it was in good working order I started building a table for it. Plans were to keep it a portable one piece self contained unit.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Finished at last
    [​IMG]
    [​IMG]
    A few parts and critters too:
    [​IMG]
    [​IMG]
    [​IMG]
    The only draw back to this table is the 2'x2' size it cuts, so I am using it to make the pcs / parts for a 6'x12'.
    I will do a write up on that when it is finished. Feel Free to ask away with any questions..
    Steve
    nwaPLASMA likes this.
  2. Kchoghead
    Kchoghead Well-Known Member
    76
    11
    28
    looks like you got it
  3. SegoMan Designs
    May 17, 2017
    11
    Thanks Doug,
    It's was a good learning experience, what I learned on that build I am applying to the 6'x12' table.
  4. LECS-Chad
    391
    129
    Great idea! Those 2x2s were perfect for the smaller facility and mobile/cart cutters.
  5. SegoMan Designs
    May 17, 2017
    11
    Chad,
    The 6x12 is going to be the same concept just bigger. If I want to move it to another part of the shop just raise the leveling legs and roll away..
  6. LECS-Chad
    391
    129
    On that bolt together I would assume you are putting some cross members to the base of the legs will help rigidity along with keeping things square overall.
  7. SegoMan Designs
    May 17, 2017
    11
    Correct,
    The main frame is 10" H beam, laterals are 4" I beam strapped in place with corner brackets as well:
    [​IMG]
    [​IMG]
    350 gal water tank & 250 gal water table = 3/16" HR:
    [​IMG]
    [​IMG]
    Water tank supported by 6" C and 14" inch I beam:
    [​IMG]
    [​IMG]
    The legs are 4"x6" rect. 1/2" wall, The casters are rated to 16k each. The 2-1/2" x 1/4" square
    tubing leveling legs will be attached via the two 5/8" holes top / bottom of Segoman.
    [​IMG]
    I am going to pump this table so I can incorporated a filter / separator
    to prolong water changes and save $ on anti-rust chemicals.
    [​IMG]
    Strong Enough?
  8. Larry Cameron
    92
    21
    Yeah..... ahhhh I think it is pretty strong enough. !!!!!!!!!!!!!
    Larry
  9. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    138
    28
    Somebody's getting serious. Nice work
  10. LECS-Chad
    391
    129
    That might... MIGHT be strong enough... ahhahahaa.... to hold a TANK!
  11. SegoMan Designs
    May 17, 2017
    11
    Thanks for the comments,
    Anyone that has used C's or I's are familiar with the 10* angle on the beam flanges making it hard to bolt things together with out a wedge washer, This required drilling and tapping of 100's of holes.
    Drill jigs were incorporated to make "E" all of the above fit when it was bolt together time:
    [​IMG]
    [​IMG]
    Tap time:
    [​IMG]
    Braking of the water pan I had to leave a notch on the ends to allow for the punch as the machine shop did not have sectional punchs :
    [​IMG]
    LECS-Chad likes this.
