Cannot open .gm file getting vmd.exe error
Discussion in 'CNC Cutting' started by scbron, May 24, 2017.
  1. scbron
    scbron Member
    Apr 29, 2016
    11
    I can open the VMD software, datum the torch, and move the torch manually with the arrows. When I try to open a file I am getting a Windows error message that the .exe file is not working and the computer is closing the program.
    Has anyone else seen this. I was able to open a file once and when I went to do it a second time I get the error message.
    Running Windows 10 64 bit machine provided by Lincoln.
    391
    129
    Can you open the LINE SPEED TEST? Or a part made from the CUSTOM SHAPE LIBRARY? If yes then I would double check your steps generating the .gm format code out of the TMCAD.
    If you crash opening up the line speed test or custom shape then I would uninstall the VMD. Remove the folder C:\Program Files (x86)\Lincoln Electric\Torchmate Controller Data.
    Restart the computer and download/install VMD again.
