Business logo mounted on wood
Discussion in 'DIY Projects' started by nwaPLASMA, May 17, 2017.
  1. nwaPLASMA
    nwaPLASMA Well-Known Member
    347
    144
    36" business logo. Customer mounted on wood.
    [​IMG]
  2. BlueSteel
    BlueSteel Active Member
    Dec 15, 2016
    40
    looks great. how did you mount it?
  3. nwaPLASMA
    347
    144
    I welded studs to the back, made spacers out of 1/2" tube. Notice I even stud mounted the center of the "O". I'm gonna start welding studs on all my stuff if I can. Much cleaner look. I'd like to have a cd stud welder but they are mucho $$, even for a used one.
  4. BlueSteel
    Dec 15, 2016
    40
    Every time I tried to mig or even tig something on the back you see the HAZ pop through the front. Then grind it down and even after sanding it sticks out.
  5. nwaPLASMA
    347
    144
    I don't weld, i use a heavy tack. That helps. And then I sand with 120 on a da. They all come out for me. If you lay a bunch of heat to it it will create a spot that's not fixable. And I've seen 14g is about the limit. Any thinner and it's a bigger issue obviously.
  6. OcalaWill
    117
    That looks really great. What kind of wheel or disc do you use to get that cool swirl pattern?
  7. nwaPLASMA
    347
    144
    120g 3" zirconia disc on a die grinder then gloss bare metal clear.
    OcalaWill likes this.
