ACCUMOVE Ohmic Relay Installation
Discussion in 'CNC Cutting' started by Torchmate, Dec 15, 2015.
  1. Torchmate
    Nov 25, 2015
    195
    44
    Installation Instructions
    1.) Cut the ohmic sensing wire (Orange Wire coming from the VFC box). Leave enough wire so that they can be stripped and screwed into the relay box. Depending on where the computer cabinet is located in relation to the VFC, the wires may need to be extended by splicing on additional wire.
    2.) After cutting the wire, connect both of them to the Ohmic Relay box using the 2 middle screws on the side of the ohmic relay box. The orientation does not matter, they can be connected either way.
    3.) Insert the ‘Pigtail’ coming out of the relay box into the Accumove 3 controller. There’s only one place it fits. Always ensure that power to the Accumove 3 controller is off when inserting or removing cables
    DanGeorgian likes this.
  2. Local302
    Local302 Member
    Apr 19, 2017
    What happens if you wire it to bypass the ohmic relay box?
  3. LECS-Chad
    391
    129
    Then your OHMIC becomes material finder and collision detection. Also pending on your grounding setup this could damage the AM box.
  4. chad
    chad New Member
    Jan 15, 2017
    do i need a relay for Accumove 2??? or is it only needed for Accumove 3??
  5. chad
    chad New Member
    Jan 15, 2017
    do i need a OHMIC relay for accumove 2?
  6. LECS-Chad
    391
    129
    Any ACCUMOVE system needs or has a relay for the ohmic pending on when you purchased your machine.
