4bt cummins jeep tj
Discussion in 'Vehicle Builds' started by Jon Reiley, Mar 3, 2016.
  1. Jon Reiley
    Jon Reiley Member
    Mar 3, 2016
    10
    8
    Here is a look at my Cummins powered jeep project
    IMG_20160228_103233.jpg IMG_20160224_175843.jpg IMG_20160207_195357.jpg IMG_20160201_152532.jpg 20160127_114525.jpg FB_IMG_1453747395118.jpg post_image5.jpg post_image11.jpg
    LECS-JR, Ben DeLap, Matt and 2 others like this.
  2. Matt
    Matt Well-Known Member
    29
    Nice Jeep, what are the specs? Goal for the build?
  3. Dnmeistr-LECS
    301
    72
    Nice seeing a Cummins in a TJ, interested to see what motor mounts you come up with.
  4. Jon Reiley
    Jon Reiley Member
    Mar 3, 2016
    10
    8
    The jeep started as a 2000 tj sport, the goal is to get a decent daily driver the has pretty good trail capability, the motor should be about 200 hp and north of 400 lb ft of tq, I am looking for a good set of super duty axles that I will cut and narrow for a custom fit and spline new axles in my mill, new long arm suspension is getting built for front and rear as a start
    LECS-JR likes this.
  5. mcctd
    mcctd New Member
    Mar 24, 2016
    What are you using for a transmission and transfercase, and how are you adapting them? I have similar plans using a 3.9 4bt and would like to use and automatic.
  6. Jon Reiley
    Jon Reiley Member
    Mar 3, 2016
    10
    8
    I am using the nv3550 till it let's go, the case is stock till I find a suitable replacement, the 4bt I bought cam with the ford t19 transmission so I used the novak nv3350 to small block ford adapter
  7. Jon Reiley
    Jon Reiley Member
    Mar 3, 2016
    10
    8
    We are getting pretty nice cuts
  8. 2CUTS2GO
    2CUTS2GO Active Member
    Aug 24, 2016
    32
    It nice to have a cnc table and nice work.
