1997 Ford Desert Chase Truck Bumper Build
Discussion in 'Vehicle Builds' started by El Jefe, Dec 12, 2015.
  1. El Jefe
    El Jefe Advanced User Staff Member
    Dec 1, 2015
    120
    This is my Cheap Chase Truck build. I bought this truck at the auction for $1300 a few years ago and upgraded it to use for pit support and chase duties for off road desert racing in Nevada, California and Baja California. The truck also works well for camping and home improvement projects.
    This is an over view of the front winch bumper I built using a Torchmate 2x4 Growth Series table with my Son.
    MikeBoyle, DrewP and Nick Bihun like this.
  2. El Jefe
    Dec 1, 2015
    120
    The Front Clip of the truck was damaged when I bought it so I replaced all the sheet metal with Fiberglass designed for off road racing. This allowed the installation of larger tires without a lift kit. The front bumper has been removed so we can start the design process.
  3. El Jefe
    Dec 1, 2015
    120
    Since my CAD skills don't allow for modeling a full truck, I decided to use foam board available at my local office supply to build a full size model of the bumper. This would allow me to install the model and see if I liked the way it fit and looked on the truck.
    Duct Tape helped me hold it all together, as well as a few pieces of scrap metal.
  4. El Jefe
    Dec 1, 2015
    120
    Using foam board gave me a lot of flexibility in my design.
    Design-Cut-Build-Front-Bumper-16.jpg Design-Cut-Build-Front-Bumper-17.jpg Design-Cut-Build-Front-Bumper-18.jpg
  5. El Jefe
    Dec 1, 2015
    120
    Here you can see the basic design coming together.
  6. El Jefe
    Dec 1, 2015
    120
    I wanted the top to follow the contour of the body. To match the shape I set up a number of reference points with my straight edge. This would allow me to transfer the shape to both sides evenly. I used a home made angle finder to verify I had both sides even, and a smaller speed square as a method to transfer my data points.
    Design-Cut-Build-Front-Bumper-111.jpg Design-Cut-Build-Front-Bumper-112.jpg Design-Cut-Build-Front-Bumper-113.jpg Design-Cut-Build-Front-Bumper-114.jpg
  7. El Jefe
    Dec 1, 2015
    120
    This flexible drafting tool holds its shape so that I can transfer the contour over to the foam board.
    Now I just need to transfer the shape to my foam board
    I cut this out with an razor blade and test fit the piece.
  8. El Jefe
    Dec 1, 2015
    120
    I made a reflection of the first piece for the other side to finish off my top plate.
    Now you can see my bumper start coming together.
    Because I only have a 2x4 table I had to keep in mind my cutting table limits. I would have liked to cut this out of a single sheet, but I decided it was easier for me to weld the seem than to index my cut on the machine.
  9. El Jefe
    Dec 1, 2015
    120
    Now that I have my design established I turned my 3D model into a 2D flat panel to design my CAD drawings.
    DrewP likes this.
  10. El Jefe
    Dec 1, 2015
    120
    I designed the shapes in Torchmate CAD, but I could also have taken pictures and imported the files. It was pretty short work to use my model as a template to create my CAD files. Since I had reference points on my angles I was able to just transfer my shape by hand.
  11. El Jefe
    Dec 1, 2015
    120
    Once I had the steel version of my bumper built I could focus on the mounting points, which I also modeled in foam board.
    Design-Cut-Build-Front-Bumper-129.jpg Design-Cut-Build-Front-Bumper-130.jpg Design-Cut-Build-Front-Bumper-131.jpg
  12. El Jefe
    Dec 1, 2015
    120
    Test fit of the center section of the bumper.
    Design-Cut-Build-Front-Bumper-132.jpg Design-Cut-Build-Front-Bumper-133.jpg Design-Cut-Build-Front-Bumper-134.jpg
  13. El Jefe
    Dec 1, 2015
    120
    I used the truck as my jig to build the bumper in place, this way I would not have to worry about my mounting holes missing the mark. I finish welded with the bumper on a work bench.
    Design-Cut-Build-Front-Bumper-141.jpg Design-Cut-Build-Front-Bumper-142.jpg Design-Cut-Build-Front-Bumper-143.jpg Design-Cut-Build-Front-Bumper-144.jpg
    OcalaWill likes this.
  14. El Jefe
    Dec 1, 2015
    120
    After a lot of work with the grinder and multiple sanders, I finally finished up my bumper and installed the winch. I bent a piece of DOM tube to finish it off. The two tow points in the front bumper tie directly into the frame.
    Design-Cut-Build-Front-Bumper-145.jpg Design-Cut-Build-Front-Bumper-146.jpg Design-Cut-Build-Front-Bumper-147.jpg Design-Cut-Build-Front-Bumper-148.jpg Design-Cut-Build-Front-Bumper-149.jpg
    OcalaWill, DrewP, MikeBoyle and 2 others like this.
  15. El Jefe
    Dec 1, 2015
    120
    The 10,000 pound winch fits nicely down inside the bumper. The only way it can be stolen would be to remove the entire bumper. The winch has been used many times in the last 5 years with no damage to the bumper. or the truck. The 10,000 pound rating is a little light for the truck, but in cases where I need more power I use a snatch block and rig the winch to increase my pulling power.
    DrewP and LECS-JR like this.
  16. bryanmartin
    bryanmartin New Member
    Jul 21, 2016
    Very well done. What are the specs on the material you used?
  17. Mike Pennington
    Mike Pennington Active Member
    29
    Very Nice Work
  18. nwaPLASMA
    nwaPLASMA Well-Known Member
    347
    144
    Looks great. I've never been good with multiple angles. Always impressed with those bumpers.
  19. 2CUTS2GO
    2CUTS2GO Active Member
    Aug 24, 2016
    32
    This will help me design my bumper for my truck.Nice job.
